Question Need help with multiple monitors connected to a laptop?
Feb 6, 2022
8
I have a Legion laptop. And I recently plugged in a separate 15-inch Acer monitor which is very old and has a 1024x768 resolution. When I am using it with "extend" screen I see the Nvidia GPU temperature rising a few degrees up. Like 6 - 10 degrees. For example, usually, when idle it will be 42 C and now when I am using both screens it is going high like 46C - 52C. Is that okay to plug in a different resolution monitor or is this bad and I shouldn't do this? I didn't play a game and check while the Acer monitor is plugged in but I hope there will also be 6 - 10 degrees higher than normal.
