Need help with my 1st build
lolnole
Upstanding
Oct 2, 2018
349
72
What do you plan to use your computer for? The stock cooler should be just fine for most use cases.
I only see the Seagate 1TB 5400RPM on the list. Did you have another drive that you are planning to use? This hard drive too slow to be used as a boot drive. Also, I would recommend an SSD for best performance.
The 1070 TI has been on sale recently. You should be able to find one for under $400 with the lowest around the $350 range.
Dark Lord of Tech
Polypheme
Good points on the storage, I missed the HDD being a 5400 RPM , change that for sure , too slow. I don't see a lot of builds with HDD's...Nice catch.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($154.99 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard ($110.47 @ B&H)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory ($99.99 @ Newegg Business)
Storage: Crucial - MX500 1 TB 2.5" Solid State Drive ($134.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1070 Ti 8 GB Video Card ($429.99 @ Newegg)
Case: Cooler Master - MasterCase Pro 5 ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA G3 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($59.99 @ B&H)
Total: $990.32
Generated by PCPartPicker 2018-12-28 16:18 EST-0500
Why? Because the 2600 is $50 less and out performs the 1700 in single core performance.
