Need help with my AMD build
SuperT3
5
This build will be my second. This will be an expensive rig so that's why I need you. I want this to be an expandable build and it will be used for rendering, video editing, and gaming. I have chosen all the main components (I will add some additional red lighting when i get the components) and i need someone to check for compatibility issues for this build. I want to know if i should change anything or keep it and order the parts. I'm a fan of AMD so the FX-9590 is essential. Here is the list: http://pcpartpicker.com/p/VNz2XL
AMD FX-9590 4.7GHz 8-Core
Deepcool CAPTAIN 360 273.4 CFM Fluid Dynamic Bearing Liquid CPU Cooler
Asus Crosshair V Formula-Z ATX AM3+ Motherboard
Corsair Vengeance Pro 32GB (4 x 8GB) DDR3-2133 Memory
EVGA GeForce GT?X 750 Ti
Thermaltake Core V71 ATX Full Tower Case
Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply
(Extra)NZXT Sentry 2 Fan Controller
(Already have an optical drive)
Total: aprox. $1064
I would...For my build thats the reason why i went with the 8350 instead of the i5
I got the GPU for free(used for 1 month), so for now ill be using it, i'm planning to get a better one later when I need it.
The intel i7 6700K is a great processor in terms of single core performance but AMD in my opinion because rendering and video editing requires more cores and you can utilize all 8 cores in rendering and also cost to performance wise AMD will be your best bet considering the i7 is a $300 processor and the 9590 is a $200 processor.
OdinA that's exactly why I prefer the FX-9590 over i7 6700K. I'm sure it will be perfect for what ill be using it for. What do you think? should I proceed with the build?
