need help with my build.
Ciatzo
67
Hi guys. I'm quite new to the pc building scene, and im going to build my first pc somewhere around the end of this year. I have been making a selection of components i wamt tominclude, but i'd like to have someone with more expierience verify that im not making some huge mistake. This is my curent selection:
Cpu: i7 4770k
Mobo: msi z87 G45
Case: NZXT Phantom full tower
Gpu: msi geforce gtx 770
Cooler: Thermaltake water 3.0 extreme
Ram: corsair CML8GX3M2A1600C9 vengeance 8GB 2x4 1600mhz cl9
Psu: i dont know. id like one that is good enough, but under 100€ (85 pound) if possible
Ssd: Samsung 840 250gb ssd
Wifi adapter: tplink tlwn851nd
Display: i dont know yet. I want a display with low input lagg and a price of around 150-200€, 23 or 24 inch.
My biggest trouble is that i dont kniw where to buy. I live in the netherlands, and most sites dont deliver there. I have been looki g at amazon, but its quite expensive. If anyone knows a good place to buy components in europe, please tell me.
np man,For Cooling i ll write down my opinion for the best of each type.(all capable for overclocking)
1)For a closed loop watercooling i would recomment H100i or H80.
2)For air solution BeQuiet Dark Rock Pro 2.
3)Custom waterloop a)pump/reserv.: mcp35x b)cpublock:EK c)radiator: alphacool NexXos 240 <<(i would choose custom cz it has more to offer and it can be expanded to add ur 77ogtx with no prob*u wil need more radiators thow)
**Your case btw has 2 fan's on top..those are perfect to put a radiator on !! :)
***i am sorry i cant help you with the last question cz i dont know really well and i dont want to misslead you :/
****There are a lot of solution water bases and air...you ll have to do a bit of research before making ur...
mainly gaming yes. my budget is around 1500-1600€ (around 1300 pound)
i'd want to be able to host some dedicated servers once in a while, and maybe some video editting.
u can do that with far less money... :) in fact Kiezz above answer in my question few days ago, how to make a low budget high end gaming pc...check it out Read the Best solution
By doing this u save 300+ evro so , UR choice man ;p
*btw for cooler pick something exept Thermaltake. They are ok but not that reliable.
*See how the FX-3850(eight-core) does vs the i7-3gen and i5-3gen.
BUT of course if u dont care about the money,your built is perfect :)
thanks man. i'll look in to the cheaper components, and about the cooler; would the cooler master hyper 212 evo be a good choice?
btw i forgot to mention in last post, i want to start gaming with a virtuix omni/occulus rift/araig/delta six (all vr tools) and their websites recomended this cpu.
anyway, thanks again
****There are a lot of solution water bases and air...you ll have to do a bit of research before making ur decision cz it is an important part of your pc.
