Need help with my build
thevictor795
22
Hello friends!
So I was making a mc on PC part picker, and it seems like an okay build aside from one problem. I'm not too sure about the compatibility notes which are as follows
"Corsair 200R ATX Mid Tower Case has front panel USB 3.0 ports, but the MSI H81M-P33 Micro ATX LGA1150 Motherboard does not have onboard USB 3.0 headers.
Some Intel H81 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs."
Will these damage my pc experience? Is my build okay?
*Here is my build http://pcpartpicker.com/list/3xwbXH#incompatibilities
Thank you for your feedback!
it just means, that the case has some USB 3 ports, which your mainboard doesn't support.
looking at your build, you can do better with newer components
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($190.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($41.99 @ Newegg)
Memory: Crucial Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory ($39.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.89 @ OutletPC)
Video Card: MSI GeForce GTX 1050 2GB Video Card ($109.99 @ B&H)
Case: Corsair 200R ATX Mid Tower...
Case: Corsair 200R ATX Mid Tower Case ($44.99 @ Amazon)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($52.02 @ B&H)
Total: $528.86
Generated by PCPartPicker 2016-11-25 18:45 EST-0500
That build is really nice o.o but, if I go with my build it'll still function as a computer yes? I'd go for your build, but atm I need to save cash :c
PCPartPicker part list: https://pcpartpicker.com/list/rgDWBP
Price breakdown by merchant: https://pcpartpicker.com/list/rgDWBP/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($219.99 @ NCIX US)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler ($12.99 @ Newegg)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard ($62.98 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2666 Memory ($51.99 @ Newegg)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card ($129.99 @ Newegg)
Case: Rosewill GUNGNIR ATX Mid Tower Case ($24.99 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Newegg)
Total: $532.92
Generated by PCPartPicker 2016-11-25 20:42 EST-0500
Is the motherboard reliable though? A lot of the reviews say that it only lasted for 2-3 months, and it was a pain to set up .-.
