Need help with my first build.
Lewdgrin
Commendable
Mar 29, 2016
13
Hi everyone!
So I've been researching for a while now but I'm still not 100% confident.
Will everything be compatible and fit together?
Are there any parts you would recommend to change?
Do you see any issues?
Is there anywhere I could save money?
I plan to play games at 60fps, high- ultra, 1080p
Thanks in advance!
-CPU: Intel Core i5 6600K 3.5 GHz 6MB
-Cooler: Cooler Master Hyper 212 Evo
-Mobo: MSI Z170-A PRO Intel Z170 So.1151 Dual
-GPU: XFX Radeon R9 390 Double Dissipation OC 8GB
-RAM: 16GB G.Skill Ripjaws DDR4-2400 DIMM CL15
-SSD: 250GB Crucial BX100 2.5" (6.4cm) SATA 6Gb/s MLC (CT250BX100SSD1)
-PSU: 750 Watt Corsair RMx Series Modular 80+ Gold
-Reader/ Writer: LG Electronics GH24NSC0 DVD-RW SATA
-Case: Corsair Carbide 100R
-OS: Windows 10 Home 64-bit OEM
Thanks for the replies. Will check out the cooler and psu.
What do you think about the GPU?
Is there anything cheaper thatl do as well as the r9 390 at 1080p?
+1
I own a cryorig H7, it is better than the evo for only 5-10$ more. On stock speeds with an i7 4790k, i idle at 29C and under load 50C max so you coud easily OC to 4.0 GHZ and further if you wish
The H7 also comes with its own thermal paste
I just had a look and agree it does look nicer and it's the same price as the evo where I live so I'll go with it. Thanks
No problem 😛 i hope we were helpful
I recommend you get the R9 390 Nitro card - my favorite of the 390's.
At the same price point, you get the GTX 970 which is arguably better and arguably worse. It gets better support and optimization since NVIDIA owns most of the GPU market, but only has 4GB (3.5GB) VRAM compared to 390 so the 390 will fair better at higher resolutions and in VR.
R9 390 is a slightly more powerful card in normal games, but is a beast in VR and better at higher res. due to its 8GB. GTX 970 is weaker but get better optimization. That sums it up.
Thank you for the suggestions! I've been trying to decide between the 390 and the 970 for so long and finally made up my mind on the 390. I will definitely have a look at the nitro. :)
