Hi everyone,
I'm building my first gaming PC, and these are the parts I've selected for it:
The CPU and videocard are somewhat locked in, I dont want less performance there since I want a future proof system if I want to stream. I've read that the 2700x is ideal for that, and much cheaper at my country than a 8700k. I also like to multitask so It seems like the right buy.
Am I going wrong with any of the other components? I'm not really sure about the power supply, is 520W enough? A gold one is about 30% more expensive, but it's an investment I can make if it really makes a difference.
Should i get the Tomahawk board instead of this one? It's a bit more expensive and I'm really trying to keep things in my budget atm.
My last question is how easy would this be to build? I mean, would it be connecting all the components and cables together and power up? I see some people having BIOS problems and whatsoever, and I really don't know how to troubleshoot that.
I'd really love your guys help and suggestions, thank you!
Type | Item |
CPU | |
Motherboard | |
Memory | |
Storage | |
Video Card | |
Case | |
Power Supply | |
Wireless Network Adapter | |
Monitor |
