NEED HELP with my first PC Gaming Build.
Sammy_3
Commendable
May 29, 2016
How does this build look? Anything I can improve on or doing wrong? I'll give links for product details...
CPU- AMD FX 6300
- http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286&cm_re=amd_fx_6300-_-19-113-286-_-Product
CPU COOLER- 212 evo
- http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=212_evo-_-35-103-099-_-Product
GPU- EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card
- http://www.newegg.com/Product/Product.aspx?Item=N82E16814487091&cm_re=gtx_960_ssc-_-14-487-091-_-Product
MOBO- Asus M5A97 R2.0 ATX AM3+ Motherboard
- http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873&cm_re=Asus_M5A97_R2.0_ATX_AM3%2b_Motherboard-_-13-131-873-_-Product
CASE- Cooler Master HAF 912
- http://www.newegg.com/Product/Product.aspx?Item=9SIA1UH3YS9892&cm_re=haf_912-_-11-119-233-_-Product
RAM-Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory
- http://www.newegg.com/Product/Product.aspx?Item=N82E16820104462&cm_re=RAM-Kingston_HyperX_Fury_Black_8GB_%282_x_4GB%29_DDR3-1866_Memory-_-20-104-462-_-Product
HDD- G-DRIVE MOBILE 750GB HARD DRIVE - 0G01961
- http://www.bhphotovideo.com/c/product/746518-REG/G_Technology_0G01961_750GB_G_DRIVE_mobile_Hard.html
PSU- EVGA SuperNOVA G2 550W 80+ Gold Certified
- http://www.newegg.com/Product/Product.aspx?Item=N82E16817438053&cm_re=PSU-_EVGA_SuperNOVA_G2_550W_80%2b_Gold_Certified-_-17-438-053-_-Product
Monitor- HP 22cwa 60Hz 21.5
- http://www.amazon.com/HP-Pavilion-21-5-Inch-HDMI-Monitor/dp/B015WCV70W/ref=sr_1_fkmr0_1?ie=UTF8&qid=1464572630&sr=8-1-fkmr0&keywords=Monitor-+HP+22cwa+60Hz+21.5%22
I would swap the cpu to an intel i3 6100. Not being intel fanboy here but that cpu architecture is pretty old unlike the skylake i3 supports ddr4 which improves gaming performance for low budget pc and overall a better performing cpu than your chosen amd.
Thanks for the quick reply, really appreciate it. I was mainly avoiding dual cores because there was a lot of people saying that games are going to start requiring more cores. And also does everything look compatible? And no bottlenecks?
All compatible. Bottlenecks will appear if gpu is upgraded to a better one.
Also why not change the gtx 960 for a r9 380. Slightly better perfomance than a 960 for the same price.
I don't know a whole lot about what makes one GPU better than another other than Clock speed. Could you explain why it's better?
