Need help with my gaming rig (PSU) (PLZ FAAST!!)
iAnonymous
63
Hello Guys..
Im planning to build a new gaming rig that can last me some years, but i need help finding a good psu for it.
Specs are:
i5-4670k (definitely overclocking)
Gigabyte Z87X-UD3H
Corsair (1x8GB) 1600MHz Vengeance RAM
Cooler Master HAF-912
Gigabyte GTX770
Corsair H100i Liquid Cooler
(Would appreciate any advice!!)
Thanks in advance...
Then a 750w bronze or better PSU from the manufacturers already listed by previous posters is what you are looking at.
+1 on the 4 x 2 ram as well.
I have the same mobo + cpu, you are going to like it. =)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207023
XFX P1-750X-XXB9 750W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
+ $15 off w/ promo code EMCXNXL25, ends 7/15
$69.99 after $25.00 rebate card and instant $15.00 coupon code
Made by Seasonic , best in the business.
300R, 400R, 500R are good cases, Phantom 410, Tempest 410, Antec 300/900, Fractal Design Define R4, Zalman Z11 (Plus). Usually hard to find low priced cases that can fit the H100i.
