Question Need help with my GPU - 2080 TI water cooled
Nov 18, 2024
The following image is from a HWMonitor recording after playing Hogwarts Legacy and OW2 for a little while.
I keep getting bad FPS even though my CPU works perfectly. Does anyone have any ideas?
CPU: AMD Ryzen 7 3700x (limits at max 70 degrees with 4100 MHz max clock speed)
RAM: 4 Corsair DDR 4, 30 GB total
I have a water loop but since my CPU is in the same water loop I expect that that is not the fault. Maybe it is the power supply or faulty cable? Any ways every tip is welcome!
View: https://imgur.com/EOt3jaP
What is "bad FPS" for you? 20 FPS? 40 FPS? 60 FPS? 🤔
It IS a fault.
RTX 2080 Ti FE (air cooled), goes up to 80C during gaming,
review: https://www.tomshardware.com/reviews/nvidia-geforce-rtx-2080-ti-founders-edition,5805-11.html
While yours, with open-loop and CPU in the mix, reaches 87C.
You'd be better off with air cooled GPU than it being in the loop with CPU.
Reduce the in-game graphical settings (or play at lower reso) and look if your bad FPS isn't that bad anymore.
If FPS increases, issue is with GPU.
If FPS remains "bad", issue is with CPU.
Given the low power and frequency, it is safe to assume the GPU is self throttling. Not because the CPU is necessarily in the loop, but because something else has gone wrong.
150W from a GPU is not much, and for it to still reach 87C on the core is very high.
Either there is blockage inside the GPU block, or the block is no longer making sufficient contact with the GPU die. Either way, complete disassembly is recommend to examine the block conditions, the loop condition, and the pump performance.
It IS a fault.
FPS remains bad (I call 30 FPS pretty bad), but CPU is doing pretty well, not going under 65 degrees
View: https://imgur.com/KhiwHJN
That says good things about your pump.
I suppose one thing to try before disassembly is to give the system a good shake, it could just be an air bubble trapped near the GPU cooling fins.
Yeah, something is wrong with GPU cooling. Could be air trapped inside the block, block doesn't offer as good connection to GPU die as it used to, thermal paste between GPU die and block has hardened too much etc.
But this would explain your symptoms; insufficient cooling to GPU - GPU thermal throttles - FPS drops to slide show.
