O okedairo58 Apr 4, 2018 3 0 10 Apr 4, 2018 #1 I can’t connect to the wireless network and the icon is not showing on my laptop and when I went to the settings it said “it couldn’t find wireless device on my PC” what do I do
Solution popatim Apr 5, 2018 Which laptop do you have? Did this used to work? Was anything done just before you realized it no long works, like an windows update?
popatim Titan Moderator Dec 2, 2009 38,904 980 135,890 Apr 5, 2018 Solution #2 Which laptop do you have? Did this used to work? Was anything done just before you realized it no long works, like an windows update? Upvote 0 Downvote Solution
O okedairo58 Apr 4, 2018 3 0 10 Apr 7, 2018 #3 popatim : Which laptop do you have? Did this used to work? Was anything done just before you realized it no long works, like an windows update? Upvote 0 Downvote
O okedairo58 Apr 4, 2018 3 0 10 Apr 7, 2018 #4 I use a hp laptop and it was working a few weeks ago Upvote 0 Downvote
