M MAKEuRAGE Honorable Dec 8, 2013 19 0 10,520 Dec 17, 2013 #1 Hello as you see i need help choosing a case that will fit my Asrock z77 extreme4. If anyone knows this answer can you tell me if this case will work? http://www.newegg.com/Product/Product.aspx?Item=N82E16811855002 Thanks guys!
Solution E E ess0523 Dec 17, 2013 The case matches the board perfectly. They are both ATX size so the board will fit inside of it with ease. 🙂
cin19 Titan Mar 14, 2011 15,722 218 112,340 Dec 17, 2013 #2 The MB is the ATX format, and the case can use for the Micro ATX / ATX format MB, so you are fine they are compatible. Upvote 0 Downvote
E ess0523 Honorable Oct 6, 2013 107 0 10,710 Dec 17, 2013 Solution #3 The case matches the board perfectly. They are both ATX size so the board will fit inside of it with ease. 🙂 Upvote 0 Downvote Solution
