Need help with my PC build! Thank you!
OhGodItsJoel
42
So first of all, here's my build
http://pcpartpicker.com/list/38pn7h#
Because the prices in EU are cancerous, the cheapest I could find that specific build is 974 euros. That's a bit too much for me. as I need to buy a monitor and a keyboard too. Does anyone have any options to lower the price say, about 100USD while still holding on to 1060? Thank you!
Some options:
1. Consider a I3-6100 if your main usage is for gaming.
Read this recent article:
http://www.anandtech.com/show/10543/the-skylake-core-i3-51w-cpu-review-i3-6320-6300-6100-tested
2. Unless you are multitasking, 8gb is fine for gaming.
3. Consider deferring on the hard drive until you actually need storage space. And... for a ssd, I would buy Samsung or Intel.
4. Your psu is excellent and I would resist changing it out. In Europe, you might find Seasonic 520w for equal quality priced less.
Some options:
CPU: Intel Core i3-6320 3.9GHz Dual-Core Processor (£150.46 @ Scan.co.uk)
Motherboard: MSI B150M PRO-VDH Micro ATX LGA1151 Motherboard (£72.99 @ Scan.co.uk)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory (£38.47 @ Scan.co.uk)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive (£141.98 @ Scan.co.uk)
Video Card: EVGA GeForce GTX 1060 6GB GAMING Video Card (£251.49 @ Scan.co.uk)
Case: Thermaltake Versa H15 MicroATX Mid Tower Case (£43.49 @ Scan.co.uk)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply (£91.49 @ Scan.co.uk)
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit (£90.00)
Total: £880.37
Generated by PCPartPicker 2016-08-14 21:21 BST+0100
Umm that is over 940euros. I am trying to lower the price.
Thank you for the answer!
What is your opinion, should I change the EVGA SuperNOVA 550W to this one?
https://www.scan.co.uk/products/520w-seasonic-s12ii-520-bronze-series-80-plus-bronze-dual-rail-20a-1x120mm-silent-fan-fully-wired-at
Yes, it is cheaper, equally good quality and is strong enough for even a GTX1080.
On the list above, the i3-6100 fares just about as well as the i3-6320 at 100e less.
Again, on the list above, buy a 2 stick ram kit so you can run in faster dual channel mode.
2133 speed is fine.
The list above indicated windows 10 full retail which costs more than oem.
What you get is the ability to transfer the os to a new pc(AKA motherboard) in the future.
Yeah, I found a cheap 16gb one right here
https://www.scan.co.uk/products/16gb-(2x8gb)-corsair-ddr3-desktop-pc3-12800-(1600)-non-ecc-unbuffered-cas-11-11-11-30-15v
Do you have any other (cheaper) suggestions for maybe a 8GB one?
My fault entirely. I heard that you lived in Europe and I just assumed you were in Britain.
