K KiritoAsuna Reputable Feb 7, 2016 13 0 4,510 Sep 23, 2017 #1 Good night guys, i've got a question : https://pcpartpicker.com/list/xprc8K this build only has a 450W power supply, is that enough? and do you guys have any recommendations for it? Thanks in Advance o/
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Sep 23, 2017 #2 Good build and plenty of quality power , won't even get near 300w of consumption. Upvote 0 Downvote
K KiritoAsuna Reputable Feb 7, 2016 13 0 4,510 Sep 23, 2017 #3 Thanks dude, also i just noticed that it doesn't have a cpu cooler, do you guys know any good silent cpu coolers that'll fit in that case? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Sep 23, 2017 #4 Comes with a good WRAITH stock cooler. AMD SenseMI Technology Socket AM4 Max Turbo Frequency 3.6 GHz 16MB L3 Cache 3MB L2 Cache DDR4 Support Unlocked Processor Thermal Design Power 65W AMD Wraith Spire 95W Cooler Included Upvote 0 Downvote
B blankcr8 Reputable Aug 22, 2017 388 0 4,960 Sep 23, 2017 #5 Since you don't have a motherboard you can overclock on, the stock cooler will be fine. Upvote 0 Downvote
K KiritoAsuna Reputable Feb 7, 2016 13 0 4,510 Sep 23, 2017 #6 hmmm what about the GPU? is the RX 480 better than the GTX 1060? and is the stock cooler silent? Upvote 0 Downvote
K KiritoAsuna Reputable Feb 7, 2016 13 0 4,510 Sep 23, 2017 #7 (i'm sorry for asking so many questions) does everything fit inside that case? Upvote 0 Downvote
B blankcr8 Reputable Aug 22, 2017 388 0 4,960 Sep 23, 2017 #8 Gtx 1060 is better as long as you get the 6gb variant, everything will fit in the case. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Sep 23, 2017 Solution #9 Yes and I like the 1060. Upvote 0 Downvote Solution
