Need help with my pc build
eduardo_fernan
Commendable
May 23, 2016
Ok I have
APU: amd a10 7700k
An ssd
Mobo: asus a88x-pro
8 x 1 for ram
I'm looking to upgrade to play games like witcher 3 on 1080p medium to high settings, do I need to upgrade my apu to a cpu or do I just need a good gaming gpu? If so which gpu / cpu is great for gaming for me? And will gpu prices fall when the 1080 and 1070 release? Please help first pc build thanks.
max gpu your cpu can handle is a gtx 960 or r9 380, i dont think their price will be affected
either will get you playable with tweaked medium settings on witcher 3 1080p 30 - 40 fps
the main bottleneck will be the cpu, overclocking will help a lot so if you dont have a decent cpu cooler you will need one as well
make and model of your power supply?
