Hi, i was wondering if there would be any problems with my PC build
CPU: I7-6700k
CPU COOLER: Corsair H110i V2
GPU: ASUS GTX 1080 STRIX OC EDITION
CASE: NZXT H440 2015 edition
MOTHERBOARD: ASUS Z170 PRO GAMING/AURA
STORAGE: Samsung 950 Pro M.2 512GB
POWER SUPPLY: CORSAIR AX 860I
RAM: Corsair vengeance lpx (3000mhz)
I am concerned as this is quite a high end setup, however i heard that the NZXT H440 has bad airflow inside it, i am worried that the temperatures would be too high in the case. Should i get another case or will the Nzxt h440 2015 edition be fine? Also, will overclocking the CPU to a higher GHZ be fine as it would be hotter?
Also, I went to build this on pc part picker and it says "The motherboard M.2 slot #0 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6Gb/s port is disabled." can anyone explain what this means and what feature is disabled? Thank you for your help😀
CPU: I7-6700k
