I live in Serbia and I'm going to build my first PC.Everything in Serbia is expensive so I'm buying all the parts from the german site mindfactory.de
This is my build:
1. i5 7600K Kaby Lake
2. Gigabyte GTX 1060 Windforce OC 3GB
3. HyperX Fury 2x4 DDR4 2400 RAM
4. Z270 Gaming Pro Carbon
5. 1TB HDD from Toshiba
So these are my questions:
1. Is all this compatible?
2. Could you recommend a good cpu cooler up to 150$? Doesn't matter if it's a water or an air cooler.I plan to overclock my cpu.
3. Can you recommend a good psu up to 130$?
4. (Not that important) Do you know a good cheap black/red case with a window that I can put these components into?
Sorry if my english is bad.
Thanks in advance
This is my build:
Thanks in advance
