So for around a year now, my computer has been struggling to run games. I don't think it has anything to do with my specs, I believe it has something to do with a certain piece of hardware being broken or something. I'm gonna get into detail now so this may be a long post, I'm just out of options.
Games:
PC Specs:
Tests
I've tested every piece of hardware that I know I can test. GPU, CPU, RAM and PC Temps all came back as fine. Now, I'm no expert so there is a chance I missed something that I didn't quite understand. Unfortunately, I did the tests around 5 months ago so I don't have the results. If possible I can do them again and give results.
I'm hoping that's enough information for you all. I'm not an expert at all on computers so forgive me if I've missed any vital info. I hope someone could be of help. Thanks.
Games:
- Modern Warfare 2 - Game occasionally freezes for around 30 seconds. FPS = 200-300 [max settings]
- F1 2015 - Game gets stuck on loading screen, literally doesn't do anything. FPS (when able) = 60 [max settings]
- American Truck Simulator/Euro Truck Simulator - Game freezes often for around 15-30 seconds. Happens on average every 2-5 mins. FPS = 60+ [max settings]
- Batman: Arkham Knight - Barely able to finish the game. Freezes every 1-2 mins for around 20 seconds. Textures fail to load which cause the freezing. FPS = 40-60 [high settings]
- CS:GO - Constant pak error's (read up on Google if needed). Freezes yet again. FPS = 70-120 [max settings]
- Evolve Stage 2 - Textures struggle to load. No freezing however. FPS = 30-60 [max settings]
- GTA IV - Textures again struggle to load. FPS = 60 [max settings]
- GTA V - Worst of all my games. Zlib error every time I load the game. Textures refuse to load at all. FPS = 60-80 [high settings even with graphics mods]
- Battlefield (3/4/Hardline) - Textures are really bad on this. My guns don't load meaning I can't shoot people and sometimes player models don't load meaning everyone is invisible. FPS = 60+ [high/max settings across all 3 games]
This is not all of my games, I've only listed the games that don't work or have problems working. Most of my other games run fine with only minor problems. Also, please note that with each of these games I've tried ways of fixing them with no luck.
PC Specs:
Tower - Cooler Master Storm Scout Mid Tower Lan Gaming Case Tinted Window Red
GPU - XFX Radeon HD 7950 DD Black Edition 3GB
CPU - AMD Phenom II X4 Quad 955 Core 3.2GHz Processor 4 x 512 KB Boxed - Black Edition
PSU - Corsair Builder 500W 80+ Certified ATX Power Supply
Motherboard - MSI 760GM-E51 Micro ATX AM3 Motherboard
CPU Cooler - Cooler Master Vortex Plus 54.8 CFM Sleeve Bearing CPU Cooler
Drive 1 & 2 - Unknown unfortunately, will take them out and check once the post is up
RAM - G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1333 Memory
Tests
