Hello everyone!
I have a problem with my pc which I can't solve and it's really getting on my nerves so I hope you can help me with this.
So less than a month I heard weird noise coming from the front of my pc followed by system freeze and I couldn't even turn it off so I just pulled out the cables from the outlet. Five minutes later, I turn it on again, everything seemed to be alright, I went on the Internet and then the noise and freezing started again only this time I could shut down the computer properly.
We took the computer to the computer technician, it was there like three days, and they said the pc worked perfectly fine. Surprisingly, pc worked fine for two days at my house too, then again the same problem. We took it again to the technician, again pc was three days at the service and they said it worked perfectly fine and they couldn't identify the problem. We decided to take the computer immediately to the other technician because I knew that the problem would still persist. Day after, he called and said that whoever built the pc didn't place the cables on the motherboard correctly and it could've fryed all the components. Well, turns out motherboard and psu were purchased and built in at the same shop where we took the pc for repair in the first place. So I was happy because I thought the problem was finally fixed and two days later, the issue came back. I really don't know what to do, technicians can't fix my pc so maybe you guys can give me your thoughts on this. I recorded a video so you can hear the noise around 1:55, you will hear it three times and it's the same noise that I hear before the system freezes. I couldn't record more because I had to shut down the computer: http://
In case you need to know these are my specs:
OS: Windows 8.1 Pro
Motherboard: Asus A88XM-A
GPU: Geforce GTX 1050
CPU: AMD Athlon X4 860k
RAM: 8GB
PSU: Corsair CX550
Do you think the problem could be the cable from my psu even though it's new? Because I don't understand how it worked perfectly fine three days and three nights at the sevice and
after two days at my house it doesn't? Or one of my components is dying because that guy messed up my pc when he was building it?
Thanks in advance.
OS: Windows 8.1 Pro
RAM: 8GB
PSU: Corsair CX550
Thanks in advance.
