Need help with my pc
Dec 14, 2018
6
I have a msi b350 gaming plus mother Board and I have a Ryzen 5 2400g. I can’t figure out where my case header goes on the board. My case is the Phanteks Enthoo pro full tower.
Did the box for the B350 have a sticker that says "second generation compatible" or something similar? If so then the BIOS is updated from the factory to be compatible. That is the biggest risk with a B350. @Eximo referred you to the correct page in the manual to find the connector but listed the incorrect page for details. It is on page 34 of the manual.
There is a link to the motherboard manual in softcopy. You can read the manual from anywhere...
I ALSO already answered that question... You have a risk of having an incompatible BIOS. There is no way for anybody but you to answer the question if it has something on the box that says Second Gen compatible.
I did use a browser for the PDF, not sure if it lied to me about the page vs the actual labels on the pages. Really hate it when documents are done in 'sections' instead of page numbers or when the page numbers don't start until after the index.
Either way, everything you need to know about the wiring is in the manual.
