Need help with my PCI-e from my psu
Olie123
151
What does this mean? 4 x 8 pin PCI Express power with detachable 2 pin section
Cause im getting an ASUS 1060 6gb dual OC
and it requires a 6pin. but this 'EVGA GQ 650W/750W only has 4x8 but as the sentence says: 4 x 8 with detachable 2 pin section
Does that mean i can use this PSU? cause i dont want to buy PCI molex or what its called. '
Thanks
The sentence means that your PSU has four (4) total PCIE connectors. Each connector is a 6+2 pin like this:
Your PSU comes with two (2) cables. Each cable will have two (2) of those 6+2 pin connectors.
So, you'll only need one cable, and only need to plug one of the 6-pin connectors along that cable to your GPU (leave the 2-pin unattached).
THANK YOU so much! you helped me. Also what do you think of this?
https://pcpartpicker.com/list/PsBRtJ
Im getting the 750W for 79.76 dollar on amazon. Should i go for it? the 650W is 79.95.
BTW the Masterbox 5 that im getting is MSI edition. Also do you recommend any LED light?
:^D
Thanks man!
alright but. going 16gb is a bit too much over my budget. Recommend any LED light? for the case?
Its alright. Thanks for the help! Also if i buy a single kit of 4gb and then buy 2 of those. do i then have dual channel? cause its a bit expensive? will it be the same if i buy 2 sticks of 4gb individualy and 4x2 pack?
