T Thomas Zhu Commendable Dec 17, 2016 13 0 1,510 Jul 25, 2018 #1 I just bought my monitor and it has the left half of the screen with just blurred colors and i have tried multiple cords(HDMI and DisplayPort)The monitor will get worse if i try changing the refresh rate.http://
Solution Isokolon Jul 26, 2018 there is nothing like "usual" nor is it of any comfort if it usually is, except in your case it's not try a different cable, see if it makes a difference. could be. I don't believe it personally, but it's worth a shot
Isokolon Judicious Jul 24, 2016 6,369 112 34,390 Jul 25, 2018 #2 return it? sounds broken to me. Upvote 0 Downvote
T Thomas Zhu Commendable Dec 17, 2016 13 0 1,510 Jul 25, 2018 #3 Isokolon : return it? sounds broken to me. But when I make the change sources the lines go away but when it finds a source the lines pop back up.Is it a problem the cables? Upvote 0 Downvote
Isokolon Judicious Jul 24, 2016 6,369 112 34,390 Jul 26, 2018 #4 Well do you have a second cable to test? But you were talking not about two lines but that half of the screen is blurry Upvote 0 Downvote
T Thomas Zhu Commendable Dec 17, 2016 13 0 1,510 Jul 26, 2018 #5 Isokolon : Well do you have a second cable to test? But you were talking not about two lines but that half of the screen is blurry Upvote 0 Downvote
T Thomas Zhu Commendable Dec 17, 2016 13 0 1,510 Jul 26, 2018 #6 I havent tried using a different cable.Is it usually the cables fault? Upvote 0 Downvote
Isokolon Judicious Jul 24, 2016 6,369 112 34,390 Jul 26, 2018 Solution #7 there is nothing like "usual" nor is it of any comfort if it usually is, except in your case it's not try a different cable, see if it makes a difference. could be. I don't believe it personally, but it's worth a shot Upvote 0 Downvote Solution
