Need help With my Samsung laptop
Seemly
534
So I woke up this morning and opened my laptop, I found it stuck on samsung logo, so I read guides on fixing it by going to f2 aND check if my hdd was there, and yes it was so that didnt work, when I press f4 to do complete restore, screen goes blank for few min then laptop turns off and turns on again, Urgent help needed
i7Baby
BANNED
Then either you've hard drive is faulty or Windows is corrupt.
Put the drive in a PC and do a Checkdisk on it. Also check it with the manufacturer's diagnostic software eg saegate - seatools, wd - lifeguard
Start up in Safe Mode (F8 per http://windows.microsoft.com/en-au/windows/advanced-startup-options-including-safe-mode#1TC=windows-7) and try a Computer Repair. If that doesn't work then try a System Restore (Last Known Good Configuration) If that doesn't work, then re-install Windows.
Seemly
534
Somehow the laptop suddenlysaid diagonising and it might take over hour, however 5 min later it said attemping repairs. Now I am waiting for result
