I have a build with a rtx 3070 and I don't think I'm getting as many frames as I should. I play at 1080p with a 244hz g sync monitor. I am running with like 150 fps in valorant, 140 in overwatch, and 110 in APEX. I play at medium settings in all these games (full screen mode) . I use to get around the same fps in the same system with a 3060 which I swapped to a 3070 and uninstalled the drivers and installed the new ones . I am thinking that maybe the problem is my CPU. I am running a Ryzen 5 2600 but it seems to do fine running at around 40 usage. My GPU usage is around 30 to 40 as well. I doubled checked that it wasnt a temperature problem problem but i seem to be running around the 40 on cpu and 60 on gpu degrees under load. I was just wondering what I could do to fix this
system specs
asus prime b450 motherboard
EVGA XC3 ULTRA RTX 3070
RYZEN 5 2600
16 GB (2X8) 3200 MHZ T FROCE RAM
240 DREVO SSD
1TB HARD DRIVE
650 POWER SUPPLY DONT REMEMBER THE BRAND BUT ITS GOLD CERTIFIED
system specs
RYZEN 5 2600
240 DREVO SSD
1TB HARD DRIVE
