S sethaugusth Feb 19, 2018 3 0 10 Feb 19, 2018 #1 Looking to upgrade my MoBo and CPU. Was hoping for some suggestions. http://www.userbenchmark.com/UserRun/7413290
Solution electro_neanderthal Feb 19, 2018 In case amazon Prime isn't your thing. Intel: Motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813145041&cm_re=z370-_-13-145-041-_-Product RAM: https://www.newegg.com/Product/Product.aspx?Item=N82E16820231888 Processor: https://www.newegg.com/Product/Product.aspx?Item=N82E16819117822 With the current sales it should come to around $390 USD before fees. AMD: Motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813157761 RAM: https://www.newegg.com/Product/Product.aspx?Item=N82E16820231888 Processor: https://www.newegg.com/Product/Product.aspx?Item=N82E16819113446 With the current sales it should come to around $340 USD before fees. Good luck.
electro_neanderthal Respectable Jan 22, 2018 450 2 1,965 Feb 19, 2018 #2 What's your budget? And do you want to keep the same RAM or upgrade that to DDR4? Upvote 0 Downvote
S sethaugusth Feb 19, 2018 3 0 10 Feb 19, 2018 #3 electro_neanderthal : What's your budget? About 400. Most likely upgrade the RAM as well. Upvote 0 Downvote
gigantusmagnus Reputable Dec 22, 2017 503 1 5,365 Feb 19, 2018 #4 400 USD? (pretty much tight budget) https://pcpartpicker.com/list/jT9MtJ something ryzen 3 1200 like this or https://pcpartpicker.com/list/f9ptvV intel i3 8100 **above only cpu mobo and ram ddr4 2x8gb Upvote 0 Downvote
electro_neanderthal Respectable Jan 22, 2018 450 2 1,965 Feb 19, 2018 Solution #5 In case amazon Prime isn't your thing. Intel: Motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813145041&cm_re=z370-_-13-145-041-_-Product RAM: https://www.newegg.com/Product/Product.aspx?Item=N82E16820231888 Processor: https://www.newegg.com/Product/Product.aspx?Item=N82E16819117822 With the current sales it should come to around $390 USD before fees. AMD: Motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813157761 RAM: https://www.newegg.com/Product/Product.aspx?Item=N82E16820231888 Processor: https://www.newegg.com/Product/Product.aspx?Item=N82E16819113446 With the current sales it should come to around $340 USD before fees. Good luck. Upvote 0 Downvote Solution
