Hello Guys,
So, I’m planning on building my Water-cooling rig. I've Put together some parts and I wanted to ask you if they really fit together or if there are some better alternatives.
First of all, my current specs:
Mainboard: ASRock Z370 Extreme4
GPU: Zotac RTX 2080Ti AMP! Edition (ZT-T20810D-10P)
CPU: i7 8700k
Is that enough?
PSU: https://bit.ly/2Erh4cB
My Parts I’m planning to buy:
Here I don’t know which one I should take. I would prefer the AC one but If anything goes wrong?
GPU Waterblock (EKWB has my card listed, AC one I checked the PCB-Layout):
EKWB: https://bit.ly/2GU3rGo
AC1: https://bit.ly/2tJPp1t
AC2: https://bit.ly/2EtMcb9
Case: https://bit.ly/2XyH2DN
Reservoir (2x): https://bit.ly/2IVRUsa
Reservoir Extensions: https://bit.ly/2SyGSIR
Temperature Meter (2x): https://bit.ly/2HbWO1I
LED Ring Reservoir (2x): https://bit.ly/2NAdAZe
Radiator (2x): https://bit.ly/2SCBeFp
Fittings (4x so 24 fittings): https://bit.ly/2VuOuhl
Hardtubes (2x): https://bit.ly/2EIX9Y1
Liquid Red: https://bit.ly/2SyNmY4
Liquid Orange: https://bit.ly/2IL136t
CPU Block: https://bit.ly/2tM9Pa3
CPU Block LEDs: https://bit.ly/2IL16PH
Fans (3x + 1 so 10 fans): https://bit.ly/2PHMXWx
Valve (2x): https://bit.ly/2EHr8iI
additional LEDs: https://bit.ly/2Et5IEM
CPU Paste: https://bit.ly/2ExlYHe
GPU Paste: https://bit.ly/2VxLOzy
Cleaning Alcohol: https://bit.ly/2tMWBtD
I hope I provided all the Information’s you need.
Thank you for your help
~ Z0R0
CPU: i7 8700k
Is that enough?
~ Z0R0
