Question Need Help with my WiFi
Jun 22, 2019
Hi,
I have a D-link Dir-825 and a 100mbps down 100 mbps up fiber optic connection.
The router is brand new. But, even from 6 metres away (behind a closed door), even though the signal i am getting is 5 bars, the connection is unstable in certain instances.
I can watch movies and browse just fine, youtube etc, but games like league of legends are disconnecting constantly.
IN GAME i am fine, once i get there. not really much ping spike and no real disconnections to speak of. After the game pretty much 90% of the time I get disconnected from the client (cant even get to post game lobby). Before starting a game I will disconnect 3/5 times when joining a normal que within 2-3 minutes and if its a 20 minute que I can get to about 10 minutes remaining before getting disconnecting and having to 'exit'.
My router config page is facing a similar issue. When I get to it and try to change settings or something, or even just idle there, every 30 seconds - 1 min it will show the notification in the image that indicates that the connection with the router has been interrupted.
I tried a software called Star Trinity CST which shows the stability of the connection in terms of uptime and PL and got like 97% uptime and low packet loss.
So im not sure what the issue is or how to fix it.
plz help
Urzu1000
402
9
10,815
Try updating the firmware and see if that helps resolve the issue. If it doesn't, you should contact D-Link customer support and see if they will replace it for you or help you troubleshoot the issue in more detail.
You may have just gotten a defective router. It's a bit annoying to ship it back, but if it fixes the issue, it's worth it :)
