Need help with new build!
ProfessorXXX
Hi, it's my first time posting on tomshardware and I need help choosing a power supply for my new build.
CPU: Amd Ryzen 5 1600X
With aftermarket CPU cooler Cooler Master Hyper 212X
RAM: Kingston HyperX Fury DDR4-2400 16gb kit (8gb x2)
Mb: Asus Prime B350M-A (micro atx)
Gpu: SAPPHIRE NITRO+ Radeon RX580 8GB limited edition
I need help choosing a power supply for my build, I've heard a lot of positive reviews on the Super flower brand therefore I'd prefer that brand. Also I do not know how much W power supply I need for my build...It would be appreciated if you guys helped me complete my build. Thank you!
(Btw I'd be using my old hdd and dvd drive so I have that already)
Well that build should be good with 500 watts. Do you plan on overclocking it? Also you can put your list together on PCpartpicker.com and get an idea of what type of wattage you should get. I would probably recommend the SeaSonic 520w power supply as it is quality, and not that expensive.
Thanks I will take a look at it. And yes I am planning to overclock it Maybe after a few months after the build. I've tried that website it says that 450 something watts. So if I do overclock my build will a 500/550W be enough?
