Greetings all,
I just finished polishing off a new build on Monday, and have finally settled down to see if the system is stable. Running at stock speeds (except 17x multiplier on FSB (up from 14x, plus 1:4 ram ratio as 1600ram requires 800mhz per stick)) results in a prime95 bsod in under 20 seconds. My ram timings are set at Mushkin default settings (7-7-6-18-1T). Cooling at idle is 22C on processor, 42C on video card. Under stress (Empire Total War for 3 hours) it never went above 27C. What could be causing my computer to BSOD in prime95 so quickly? Again, all other BIOS settings are at default.
Thanks!
My build specs are below:
CORSAIR CMPSU-750TX 750W
ARCTIC COOLING Freezer 64 Pro
Microsoft Windows Vista Home Premium SP1 64-bit
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black
ASUS M4A785TD-V EVO AM3
mushkin 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
SAPPHIRE Vapor-X Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16
Thanks!
