Need help with new i7 2000 CAD rig
AngeloR93
26
APPROXIMATE PURCHASE DATE: Around 2 weeks BUDGET RANGE: 2000 max 2100
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Games,internet,music,movies,photoshop.
PARTS NOT REQUIRED:keyboard, mouse, speakers, OS)
PREFERRED WEBSITE(S) FOR PARTS: newegg.ca
OVERCLOCKING: Yes but only minor
MONITOR RESOLUTION:1920x1080
ADDITIONAL COMMENTS: looks do not matter at all and im upgrading from a P4 rig with integrated graphics that cant run counter strike on max gfx
Parts decided on:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130504 ] EVGA 017-P3-1295-AR CO-OP Edition GeForce GTX 295 1792MB 896 (448 x 2)-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail [/url]
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006 ] CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail [/url]
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131365 ] ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail [/url]
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202 ] i7 920 [/url]
not sure on
Ram-Thinking about http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145222 ] CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9 - Retail [/url]
Case-no decisions at all
Fan-also don't know
Monitor-need something 1920x1080 and cheap did not include in price planning to get later
I would get this RAM over what you have listed, it has better timings and a little cheaper... OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3P1600LV6G -$119.99
Case: COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - $159.99 or Antec Twelve Hundred Black Steel ATX Full Tower Computer Case -$199.99. If these are two big, I would go with either of their "little" brothers... HAF 922 or Antec 902.
Heatsink: XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - $49.99 or Noctua NH-U12P SE1366 120mm SSO CPU Cooler - $84.99
edit: Monitor: ASUS VH222H Black 21.5" 5ms HDMI Widescreen LCD Monitor - $189.99
The rest of your build looks good. Another way to cut cost is to drop the GTX295 and pick up either of one of these two cards.. They will handle 1900x1080 with no problem. EVGA 01G-P3-1180-AR GeForce GTX 285 1GB 512-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - $378.99 or XFX HD-489A-ZDEC Radeon HD 4890 Xtreme 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - $238.49
ram is settled i like that one and the reviews are great so ram😱cz platinum
case also settled love the huge fans
still not sure on fan
