I have an older custom computer that I am using for my HTPC. I added the Edimax PCI Gigabit card to it and it wont run at gigabit speeds. I have 5 other computers on the network that connect at gigabit to the router. 3 through wired CAT6 connections and 2 through Wireless N. I have a CAT6 on this one as well but it will only run at Megabit. I have uninstalled/reinstalled the device in device manager several times and tried installing the driver from the cd and the updated driver from Edimax website and letting windows install its own updated drivers. Nothing will allow it to run at gigabit. I have tried swapping out the CAT6 for several different CAT5 and CAT6 cables and none of them make a difference.
The current driver installed is the one Windows prefers because it always updates it to this one when it searches for updates. "Realtek RTL8169/8110 Family Gigabit Ethernet NIC (NDIS 6.20)"
Speed is always stuck at 100 Mbps in the Local Area Connection Status window. On the other computers it always says 1000Mbps.
Can anyone help with this issue? I am, right now, going to move the card to a different PCI slot to see if it help but that's the only other thing I know to do. I will update with the results of the move.
Thank you.
Computer specs:
Windows 7 Ultimate x32
Abit NF7-S2 Nvidia nForce2 Ultra 400
AMD Athlon XP 3200+
EVGA Nvidia Geforce 7900 GS CO
2Gb Crucial DDR400 Dual Channel
Edimax Gigabit PCI adapter
Antec Neo Eco 520 PSU
Rosewill Challenger Case
Thank you.
Computer specs:
AMD Athlon XP 3200+
