Need help with noob budget build
Itzjt90
6
Approximate Purchase Date: This week or sometime this month
Budget Range: Max 1,000$
System Usage from Most to Least Important: Gaming, surfing the internet
Are you buying a monitor: Yes, but I'm using the HD TV for now. Ill buy a monitor later.
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg.com. its a 30 min drive to the Microcenter, NJ, Patterson.
Parts Preferences: Really would like to run Arma 2 Dayz or the Standalone. I believe the intel core i5 2500k will do. Using an HD TV for now till I get more money. Just need an OS and keyboard
Overclocking: Yes, After some more reading
SLI or Crossfire: No
Your Monitor Resolution: I really don't know. Would this monitor do?
ASUS VH236H Black 23"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
1920 x 1080
Additional Comments: It doesn't have to be quiet. Need a ok looking case. Games like Diablo 3, Arma 2, Battlefield 3. On high or at least medium.
This what I got so far.
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Western Digital WD Black WD1002FAEX 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
SAPPHIRERadeon HD 7850 OC 2GB. Is this a good GPU?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102984
ASRock Z77 Extreme4 LGA 1155 Intel Z77 Read this was a good Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
G.SKILL Sniper 8GB Came free with mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
Intel Core i5-2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
COOLER MASTER Hyper 212 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Need a power supply. I dont know which
Total so far without power supply
882.91
Not sure if you guys can see this cart =/
http://secure.newegg.com/Shopping/ShoppingCart.aspx?Submit=view
Just tell me what I should change because I want to make sure this build is good
micro center cheaper for some parts.
http://www.microcenter.com/product/388577/Core_i5_3570K_34GHz_LGA_1155_Processor
169.00 newer cpu run cooler stock voltages.
http://www.microcenter.com/product/393422/P8Z77-V_LK_LGA_1155_Z77_ATX_Intel_Motherboard
like asus it a thicker board will little better parts on the low end the the board you picked out.
this one will do sli if you need to with two slots.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
90.00 after rebate. it beter to over size a power supply if you switch out to a bigger gpu later on.
