Need help with NZXT H 440 case, don't know how to power/connect the fans
Frankximus
6
The H440 has a fan hub in the back, I'll follow up with a pic below later. I'm at the final step here, I have already put everything together, but the fans are left out. I figure for the hub to work, I only need to link one of the central cable to the motherboard, is that the case?
Or, do I need to draw a cable from the PSU to directly power the hub? If so, how can I do it?
Really appreciate any help I can get here!
No signals as nothing on the monitor? If the computer turns on and you are using an add-on card, remove it and check things on the onboard video if you have that on the motherboard. If you don't have onboard video, reseat the video card and check all the power connections.
