Question Need help with nzxt h510 elite case and x470 gigabyte gaming wifi 7 mb
Jan 29, 2021
So my issue is the nzxt h510 elite has a cable that is 4 pins that would go to mother board but the gigabyte gaming wifi 7 x470 doesn't have anywhere for it. I'm pretty sure this is the led cable for the light strip in case. What.kind of adaptor would I need and where would this plug.
From case description:
2x RGB LED channels, each support up to 4x HUE 2 addressable LED strips or 5x Aer RGB 2 fans
*Note : If a splitter is used, fan control is regulated depending on the fan connected to the 4-pin port . Do not use low-noise adapters.
RGB LED Lighting2x Integrated Aer RGB 2 140mm Fans
1x Integrated addressable LED Strip
From MB specs:
  • 2 x digital LED strip headers
  • 2 x digital LED strip power select jumpers
  • 2 x RGB (RGBW) LED strip headers
Sooo, that plug should go one of connectors from first line.
From MB specs:
There are led connectors problem is the one coming from case has pins and not one for pins to plug into
