Need help with OC i7
wfb123
Commendable
Oct 21, 2016
15
Hey everyone,
So I have run into an issue with overclocking my CPU and I am hoping someone can shine some light on it.
I have managed to get a stable overclock at BCLK freq 208(4.368MHz) @ 1.32500 vcore & 1.25000 qpi with HT off but for some reason I can't get to BCLK freq 209(4.389MHz), I even tried raising the vcore all the way to 1.45 and qpi to 1.4.
Does this mean I've hit a wall with the overclock or is there something else I should be changing in the bios? as I feel like for a 0021 MHz difference, a 0.13 vcore increase should be more than enough. I know 0021 Mhz is hardly any difference in performance but I'm hoping to go beyond this if it's possible as my temps are low at max load.
I have a old i7 920 d0 chip.
Cooler Master Nepton 240M Liquid CPU
G.Skill Ripjaws X CL9D 8GB (2x 4GB) DDR3 1600MHz
asus p6x58d-e
GTX 1060
Current bios :
Code:
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[208]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1667MHz]
UCLK Frequency.........................[3368MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.32500]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.25000]
IOH Voltage............................[1.14]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Disabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
Edit: I was running a 4.41GHz overclock (BCLK freq 210) @ 1.39375 vcore but it would fail in intelburntest and crash occasionally while gaming
MERGED QUESTION
Question from wfb123 : "Need help with OC i7"
