Hey guys. Sorry, second time I have to write this from scratch! You would figure a site like this could remember my post when it gives me a "you are not logged in error" but nooo! =).
First of all, I have OC'd my CPU to 3.5ghz using the built in horrible "Step up my CPU" feature of my BIOS. With an overnight Prime95 test stressing my CPU I never go over 52C.
Here is the basics of my rig:
CPU: E8500
Mobo: Striker II Formula
RAM: Corsair DDR2-800, CL 5-5-5-18
GFX: Dual 9800GX2s (Quad SLi)
I seem to be getting horrible FPS in some games compared to a friends system. My GFX power is vastly better than his, but he has a quad core extreme chip, I have the core2 duo. To compare:
Team fortress 2, on his system with maxed setting he is running at 100FPS when the action starts and in large open areas. For me, I run at 40fps with my settings on low!
Some people have told me I need to OC my chip so it can better handle the 4 GPUs (I have also played using only 1 of the cards, and it made no noticeable difference to my FPS). Also I have 4GB of RAM, yet someone told me that each of the cards uses up 1GB? Each card also has 1GB of on board RAM, so I am not sure what this personw as talking about, it is however a bit concerning.
The problem is I dislike the idea of using the built in BIOS settings to OC my chip without me actually doing anything. So I was curious if anyone with a similar setup has had success in getting this chip to 3.8ghz or so, air cooled (not a stock fan, I forget the name, however it is a very large circular copper heat sink, with the fan in the middle, it is perpendicular to the cpu). Also I would really appreciate it that if you suggest something to try, you also explain why =). I really want to understand this process instead of blindly following someone elses settings =)
Thanks a lot and greatly appreciate the time you took to read this!
CPU: E8500
