• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Need Help With Older External Hard drive.
rashadd26
Commendable
Nov 14, 2017
4
The usb part came loose and need to get data off. Need a solution... Do I need adapter. The part is wd1001fals external. Asking b/c I want to be sure on ordering the correct parts.
rashadd26
Commendable
Nov 14, 2017
4
Seems like just a regular HDD woth a bay mounted. If the HDD hasn't failed in any way, you should be able to use it just like another secondary drive.
So just remove the green part and I can plug it straight into the motherboard? K thanks
