Question Need help with overheating issue
Jan 18, 2023
Hi everyone
Well so i got this notebook Msi GL-65 leopard 10sfsk and happened to be great one until few months back ... currently gpu overheating and decreasing performance a LOT, can't even run AOE3 on 60fps
Specs:
RTX2070S
Processor Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz
Installed RAM 32.0 GB (31.8 GB usable)
Under normal standarts this device should be able to run game as AOE3 at ultra, settings does so as default but performance is awful, i have cleaned the dust inside, changed thermal paste and pads but no luck
any ideas about cause of issue would be helpful <3
Ralston18
So all was well at first and then the overheating problems began. Correct?
Use Task Manager and Resource Monitor to observe the notebook's performance. Use both tools but only one tool at a time.
Observe first without AOE3 running. Then launch and play the game as usual and continue to watch the tool.
Try to discover what changes when the gpu begins to overheat.
Could be some other app in the background now launching and starting to run.
Jan 18, 2023
So i have done it and there werent any problem at anything beside GPU, inside gpu section for '3D' is peaking at 100% and overheating at 93* but as soon as i open task manager while gaming everything sets down and when i get back to game again same 3D is peaking at 100% with overheating
