[SOLVED] Need help with parts for a new build!
Feb 27, 2019
12
Needing help to see which is the best parts you guys would recommend for me towards either a new AMD or Intel build. I have a budget of $1200 with $1300 being the max and I do my buying new parts on Newegg. The parts im needing to get are a new CPU, GPU, Memory, SSD, and Motherboard because Im gonna reuse the other parts from my current PC. So just needing to see which is the best parts to get for that build for either an AMD build or Intel build and I'll see which one I'll go for.
WildCard999
Herald
This would be good for 1440P/3440x1440P & 4K (High-ish settings). If your using it at 1080P I'd recommend using Nvidia DSR 2X at the very least as that will be utilize the GPU and make your games look a bit smoother over AA settings.
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor ($309.99 @ Newegg)
Motherboard: ASRock - B450M Steel Legend Micro ATX AM4 Motherboard ($93.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($110.98 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive ($69.95 @ Newegg)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card ($706.98 @ Newegg Business)
Total: $1291.88
Generated by PCPartPicker 2019-03-03 18:30 EST-0500
If you want RGB memory to go with the RGB CPU cooler & motherboard then swap it to this.
Memory: Team - T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 Memory ($109.99 @ Newegg)
Total: $109.99
Generated by PCPartPicker 2019-03-03 18:36 EST-0500
Reactions: agentshadowolf
Feb 27, 2019
12
Total: $1291.88
Total: $109.99
nice for an AMD build, gonna keep note of this. What do you have for an intel build?
WildCard999
Herald
Probably this...
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor ($379.99 @ Newegg)
CPU Cooler: Corsair - H100i PRO 75 CFM Liquid CPU Cooler ($104.99 @ Newegg Business)
Motherboard: Asus - PRIME Z390-A ATX LGA1151 Motherboard ($189.99 @ Newegg Business)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-2666 Memory ($77.99 @ Newegg)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card ($469.99 @ Newegg)
Total: $1292.90
Generated by PCPartPicker 2019-03-03 19:07 EST-0500
...although price to performance I'd take the AMD build over this easily.
Feb 27, 2019
12
Probably this...
Total: $1292.90
alrighty then thank you, looks like i'll go back to AMD lol
