Hello everyone.
I need your help to build a desktop PC for using 3-D Modelling Software AutoCAD solidworks, ANSYS (CAE Software), as well as Medium Gaming (FC4, BF Hardline, ARMA 3, ect).
PARTS NEEDED:
1.CPU (mostly i5 3rd/4th/5th Gen?)
2.Motherboard (Suitable)
3.RAM (8 GB ddr3 single stick)
4.PSU (how much volt, amps?)
5.Cabinet/Case (Cheap One)
6.CPU Cooler (not liquid cooling, just basic fan cooler/stock cooler)
7.Anything Leftout?
PARTS I WILL BE REUSING:
1.Monitor (Samsung SA300 19")
2.GPU (Ati Radeon HD5450 1gb ddr3 (will be using it temporarily ))![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
3.HDD (1x500 GB Toshiba, 1x256 GB Sony)
4.Optical DVD Drive (Toshiba)
5.Mouse, Keyboard, Speakers
6.OS windows 8.1/10 64-bit
I live in Mumbai,INDIA.I will be buying parts locally only.
Apart from the above requirements, the system should work smoothly for next 4-5 years.
My Budget is 45K INR as mentioned in the title.
Also i will be installing Linux (Ubuntu/Gnome 64-bit in the 256 GB drive),
so will it cause any issues with win 8.1/10 ?
Also i will be adding a new GPU later when i can stretch it
PARTS NEEDED:
7.Anything Leftout?
