[strike]Hello! I have just finished my pc build. I have a Gigabyte Z170x Gaming 3 G1 Gaming motherboard and 4x4gb ddr4 ram on all the slots. An intel core i5 6400 and the cooler correctly installed. I have a GTX 750 ti GPU. When I turn on the pc, the fans start for about 5 seconds and then the pc turns off completely. Then 5 seconds later it turns on and then 5 sec later back off. You get the idea. What did I do wrong? I checked the cooler, it is correctly plugged in. The ram are well seated. This PC is an upgrade from my last toasty pc. There are some cables like the CD reader cables that were not compatible with my motherboard so I removed them. The only part where I might have messed up is with the GPU. There is a cable ( 6x6 wholes ) that I have to plug into it. But then it splits to 2 different cables. 6 Cables come out of the 6x6 whole, 3 of them go into a 4x4 connectors which i think connect to the power supply, so on both 4x4 cables there is an empty whole. All of the 6 cables from the 6x6 GPU whole that divide into 3 in 2 different cables. . What could be the issue? Do you want me to add a picture of the graphics card?[/strike]
[strike]OLD UPDATE!: I was trying to boot with 4x4gb ddr4 1400 Ghz ram and it gave me a beep error. I removed 3 of them and left only 1 ddr4 4GB ram stick and it managed to boot. Why is it not working with 16 gb of ram? I am running 64 bit windows.[/strike]
NEWER UPDATE! I have booted 2 ram sticks in a dual channel slot, it booted fine, but when I go to task manager it sais that ram available is 2.1GB of the 8 GB I installed, I know windows 10 64 bit uses 2 GB of ram to work, but why does it only show 2.1GB available? It is also written: "Commited: 2.2/7.1 GB" what does this mean? How can I boot 4 sticks of 4 GB of ram on a dual channel pc with 4 ram slots? What is a good website to post pictures or screenshots? (I know there are but I forgot links)
