Hey, I'm going to be putting together a build for heavy gaming and editing. I just want some opinions on my build. The two fans are going to go on the bottom and will replace the ones that come with it later in time. Should I go for the Trooper or the Stryker? I personal like the Looks of the trooper but I really don't know the specifics. Are undividually sleeved wires worth it if I don't care about looks? Can you just take a look at it in a while. http://pcpartpicker.com/p/42NW8d Do you think the 6 fans will be enough to run at a low enough temperature.
