Need help with pc build !!
Viraj Nagre
15
Hey folks, seeking some help regarding a new pc I want to build.
My budget is around Rs.40K and this is the configuration I've chosen
cpu - r3 1200
mobo- b350m
psu- vs450
ram- vengeance 8gb ddr4
1TB hdd
and a budget case that'll cost around 1.5k and a monitor for around 7k.
Now I wanted a gtx 1050ti but with current situation in market I was advised to wait for some time, if I wait I'll have to get a cheap temporary gpu to accompany r3 1200 so now,
1. is this a good configuration for gaming?
2. Should I wait another 1-2 months for 1050ti?
3. should I go with 1200 or intel g4560? with 4560 I wont have to use temp gpu
and most importantly
4. I'm going to buy parts from Mumbai's Lamington road and would lllove some advise as to what should I check to confirm product authenticity, which bills(vat, gst etc....) should I ask for to ensure safe warranty claim in future?
If you've read this much....thank you and thank you in advance for suggestions!
First, just an FYI, watch out for the pricing on PCPartPicker India, it often is significantly too low. For instance, A320M-HDV is listed as ₹3343.28 on PCPartPicker but is ₹5066.08 on the Amazon website.
https://www.amazon.in/dp/B06XNRWM3C/?tag=pcp03-21
I often use these websites for pricing in India
https://www.theitdepot.com/
https://www.mdcomputers.in/
https://www.primeabgb.com/
Lamington road is the technology market area in Mumbai where you can barter for goods.
We also have the release of the Ryzen 2400G on 12-Feb-18, it might be a good option as well. And yes, the i3-8100 would be fantastic choice if it wasn't for the mobo pricing.
If you want the PC right now, then buy the ryzen3 1200. But if you can wait, may consider the intel i3 8100, becuse right now you have to buy the expensive z370 for the i3 8100, and intel say they will launch H370, B360 in Q1'2018. But we don't see them yet so we don't know when they are available.
And the i3 8100 is better than ryzen3 1200, and the ryzen 3 is better than the intel g4560. Here is the reviwe https://www.techspot.com/review/1499-intel-core-i3-8100-i3-8350K/
I put the ryzen3 and intel i3 8100 ( without the 1050ti with Z370 motherboard) lists for you. And I don't know the shop ( Mumbai's Lamington road), all I list the parts are from amazon.in
For the GPU price, if you only wait 1-2 months, the price will not go down, but nobody will know what happens in next 1-2 months, even one year later, because as long as the coin mining is still going, the gpu price will not go down.
The AMD ryzen 3 1200
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor (₹7679.00 @ Amazon India)
Motherboard: ASRock - A320M-HDV Micro ATX AM4 Motherboard (₹3343.28 @ Amazon India)
Memory: Crucial - Sport LT 8GB (1 x 8GB) DDR4-2666 Memory (₹5884.68 @ Amazon India)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (₹3246.00 @ Amazon India)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card (₹15975.00 @ Amazon India)
Case: Deepcool - DUKASE V2 ATX Mid Tower Case (₹2868.44 @ Amazon India)
Power Supply: Corsair - VS 550W ATX Power Supply (₹3296.00 @ Amazon India)
Total: ₹42292.40
Generated by PCPartPicker 2018-01-27 00:51 IST+0530
For intel i3 8100 ( without gtx1050ti, plus the MB is Z370)
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor (₹9959.00 @ Amazon India)
Motherboard: MSI - Z370 SLI PLUS ATX LGA1151 Motherboard (₹8693.60 @ Amazon India)
Total: ₹33947.72
Generated by PCPartPicker 2018-01-27 00:53 IST+0530
