Need help with PC case
I can't find the interior dimensions on that case >.< However based on the overall dimensions it's either 17.2" or 17.95" in length (I think it's 17.95" but I'll use the other one to be on the safe side) With the bays being 5.25" that leaves 11.95" for you card. Your card is 11.5" so it should fit. As for width your card is 5.08" and the case is 7.36" so no problems there. Your motherboard's width is 11.69" so that will fit and your psu is normal so should be fine. The So I'd yes, it will fit. Although your motherboard's depth is 2.26" and your card being 5.08" means it will be a tight squeeze.
