Need help with PC config for University
G
Guest
Guest
Archived from groups: alt.games.the-sims (More info?)
Hi,
I just bought The Sims 2 university, and the game is reeeeally slow. My
configuration is the following:
- 2400 athlon
- graphic card with 80Mo (RADEON 9700)
- hard drive with 40 Go free space
- 512 Mo memory DDR
Do I need to add some memory? It seems to me that I already have enough....
Can anybody help me?
Thanks in advance
Arnaud.
"Arnaud" <arnaud.g@NOSPAMnoos.fr> wrote in message
news:4239fb0f$0$1623$79c14f64@nan-newsreader-07.noos.net...
> Hi,
> - 2400 athlon
> - 512 Mo memory DDR
> enough....
I have 512 and my game is very smooth and not at all slow. I did install
more at one time but my motehrboard had a fit over it so it is gone again.
While the game was somewhat faster at thingsd like loading and saving with a
gig it wasn't really game altering. Couldn't tell what you meant by 80 mo
for the graphics card. The amount of video memory can be a huge factor.
Gareeth
I meant 128 Mo of memory, sorry.
"Gareeth" <Gareethnews@hotmail.com> a écrit dans le message de news:
39un3bF64icfvU1@individual.net...
>> Hi,
>> - 2400 athlon
>> - 512 Mo memory DDR
>> enough....
> a gig it wasn't really game altering. Couldn't tell what you meant by 80
> mo for the graphics card. The amount of video memory can be a huge factor.
> Gareeth
news:423a6c53$0$6884$79c14f64@nan-newsreader-06.noos.net...
Well as far as specs go you have me beat then. Must be something else.
Gareeth
On Thu, 17 Mar 2005 21:54:01 -0800, "Gareeth"
Either he's set the game to insane-o-resolution or something is indeed
very wrong.
Arnaud wrote:
> Hi,
> - 2400 athlon
> - 512 Mo memory DDR
> Thanks in advance
> Arnaud.
A quick 2c - my game runs HORRIBLY slowly whenever i have, for example,
a browser or trillian open in the background.
~SL
Arnaud wrote:
> Hi,
My
> - 2400 athlon
> - 512 Mo memory DDR
enough....
> Thanks in advance
> Arnaud.
I found that increasing memory from 512mb to 1 gig improved load time
performance significantly, for example switching back and forth between
neighborhood view and a lot. It definitely improved performance when
in a large house with many sims and objects. However, in a simple
neighborhood without many houses and objects you probably won't notice
much of a difference with more memory.
A RADEON 9700 should be fine for the game, assuming you have the latest
drivers.
Make sure you have defragged your hard drive and like mentioned in a
previous posts, create a very basic profile just for playing sims 2.
> have, for example, a browser or trillian open in the
> background.
I applied this
http://groups.msn.com/TheSims2Database/makeyourgamerunfaster.msnw
lately, and it helps. The idea is that you make a seperate
account for your game, which is stripped of everything else. I
found it here a few weeks ago. I can recommend it to everyone.
T.
Am Fri, 18 Mar 2005 20:05:14 +0100 schrieb Taemon:
> I applied this
I second that, it's amazing how much faster the game is!
Dorte
Hi,
I tried to create a basic profile for my game, and it works better. My
characters ' movements are much smoother, though sometimes still not as much
as they could be. Loading nieghbourhoods, and the first minutes or so of
game in "complex" neighbourhoods, are still rather slow, but I assume this
could be fixed with more memory, as you mention it?
The antivirus and firewall (both Norton) still load automatically, even in
the basic profile, and I believe they are part of the problem. I have to go
to the taskmanager to eliminate them. Does anybody know how to impede them
from starting under the "basic profile" without changing the configuration
under other profiles?
Thanks to everyone for your help and advice
Arnaud.
"Tom" <tom_overton_1968@yahoo.com> a écrit dans le message de news:
1111183893.812569.242270@g14g2000cwa.googlegroups.com...
> Arnaud wrote:
>> Hi,
> My
>> - 2400 athlon
>> - 512 Mo memory DDR
> enough....
>> Thanks in advance
>> Arnaud.
> drivers.
Don't you take them out using msconfig? Look in the start up options (go to
Start/Run and type in msconfig). Be careful though if you have a permanent
internet connection - you shouldn't turn them off in that case. Either that
or unplug your broadband or switch off your modem before you start up the
computer (don't unplug/plug a modem when the computer is running - you can
damage the electronics - according to my electronics engineer husband).
Best wishes
Maxon
news:423d3088$0$9219$79c14f64@nan-newsreader-07.noos.net...
> Hi,
much
go
> Arnaud.
> > Arnaud wrote:
> >> Hi,
> > My
> >> - 2400 athlon
> >> - 512 Mo memory DDR
> > enough....
> >> Thanks in advance
> >> Arnaud.
> > drivers.
