Okay so about two weeks ago my pc started crashing after 10 hours of useage.
My monitors would turn off and show no signal and fans would speed up then the crash.
my pc specs :
Amd 5 2700
Rtx 2060
16gb ram
i thought it was the ram problem so i reset my ram twice but that didn’t help.
When it crashes i would just turn it off and sleep then wake up the next morning to see the pc totally fine. There is no problem when im using it or booting it, it just randomly crashes after 10h of use.
Could this be just bad ram? Or any other problem? I want to know what the problem is so i can fix it. I haven’t overclocked the pc either.
my pc specs :
Amd 5 2700
Rtx 2060
16gb ram
