Need help with PC motherboard
crowgaming
15
Hello everyone I had a friend introduce this build to me and I really liked it. The only thing I have in this build that isn't on it is a processor. I currently have the i7-4790k and I was curious if it would work with the motherboard from this build http://pcpartpicker.com/list/BBV9NN
I am extremely nervous about all of this because I have never built a computer(currently using a stock alienware pc.) Any help is appreciated.
If it doesn't work or any other pieces do not work can you recommend something that will. I am extremely bad with these things and someone told me that the cpu and the ram do not match up and I already bought everything. I would prefer and motherboard that could work with the build.
Would it be smarter to buy a different motherboard or buy another cpu. I feel like the CPU is expensive to replace considering I got one that's really high end. Also does the ram work with this motherboard? If it does I guess I can shell out a couple hundred for a great cpu and just sell my other computer as a whole.
As long as the ram that I have listed works with the msi motherboard listed I will buy a CPU instead.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117559 would that CPU work? I apologize for asking so many questions. I just want to buy this as soon as possible trying to have this built over the weekend.
Supports the 6700k? If so awesome I will purchase right now! Sucks the 4790k went to waste pretty much. Thanks a lot for your help.
