So a few days back my CPU heat sink decided to start leaking all over my video card, It didn't damage the card thankfully, but it made my computer started running terribly and when I opened my PC to find out why I finally found my problem, So nothing seems damaged, but my heat sink keeps leaking an oily substance and I don't want to risk ruining everything can you guys help me find a replacement and also add anything else I may need to upgrade to prevent these situations.
My Setup Below
Case: IBuyPower I-Series 701
Motherboard: ASUS P7P55D-E Pro LGA 1156
https://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
CPU: Intel Core i5 i5-760 2.8GHz
https://www.newegg.com/Product/Product.aspx?Item=9SIAEEN6MF6320&cm_re=Intel_core_i5_slbrp-_-9SIAEEN6MF6320-_-Product
Video Card: MSI GeForce GTX 1060
https://www.newegg.com/Product/Product.aspx?Item=N82E16814127963&cm_re=nvidia_gtx_1060-_-14-127-963-_-Product
Power Supply: XION Xon-700p12n 700w Max
Pictures of my case and the heat sink that was leaking below
https://drive.google.com/open?id=13LI-aSVf9hgqCEH10yTpXSUb07PaaQWk
(P.S. anything like my Power Supply or Case that doesn't have a link means I couldn't find it on any websites such as NewEgg,Amazon,Ebay,Etc.
Also If any other parts that I may have missed that are important just ask and I cant get the descriptions of them to you
My Setup Below
