Hi,
i want to use more then 4 gb of ram in my system which has 6 gb total installed and win 7 ultimate 32 bit OS. I found a way on the internet (given below) and used the command as described but win 7 still says 3.24 of 6 GB usable. Can you plz guide me.
I opened a command line with elevated right run as administrator and typed the command .
bcdedit /set pae ForceEnable
I Run bdcedit and validate the result. "pae" is set to forceenable
Thank you.
Thank you.
