Need help with picking GTX 980
XLifted
15
Hey, guys
I'm looking for some specific things in GTX 980
1) Ability to overclock as much as I can (preferably to 1500 mhz or higher)
2) Card clearance of 12 inches in length max , max height of 5.80 inches (or 6" for simplicity). Judging from Asus R9 290 4GB that barely fit in height.
3) Looking for quiet fans, comparable to PCS+ cards from Powercolor.
4) Under $600 (so please no Classified, Kinpin or Matrix cards, as much as I want to)
5) Preferably with great factory overclock boost of 1300+
I'm looking to overclock like I said, and I have found a couple of cards that I found interesting.
Your opinions on these cards here after research I've done:
1. EVGA 04G-P4-2986-KR GeForce GTX 980 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487089&cm_re=GTX_980-_-14-487-089-_-Product
Any coil issues with this one? ^
Some say fans are quiet, the others not so much, so hmmm
2. PNY VCGGTX9804XPB-XP-OC
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133580&cm_re=GTX_980-_-14-133-580-_-Product
Anyone had experience with PNY cards in overclock and how are the fans in your opinion.
3. MSI GTX 980 GAMING 4G
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127834&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
How are the fans, what about overclock?
Any other equal or better candidates are welcome.
Thank you
Edit: What about Asus Strix as well? Seems to be a good overclock judging on Youtube videos
MSI Gaming and Gigabyte G1 are the overclocking leaders and MSI has best fan control and noise / temp ratio....but the Gigabyte 970 is 12.28 long so that's out. The Asus and EVGA fight for the bottom spot.
http://www.guru3d.com/articles_pages/msi_geforce_gtx_980_gaming_oc_review,26.html
http://www.guru3d.com/articles_pages/asus_geforce_gtx_980_strix_review,26.html
MSI Boost Clock Overclocked ~1537 MHz
Asus Boost Clock Overclocked ~1481 MHz
MSI Load Temp = 68C
Asus Load Temp = 71C
MSI Thermal Imaging = 56.4 - 70.0
MSI Thermal Imaging = 69.4 - 89.7
Both measure 39 dbA under load.
MSI Load Temp = 68C
See http://www.bit-tech.net/hardware/graphics/2014/09/19/nvidia-geforce-gtx-970-review/14
"Furthermore, it has the beefiest power delivery system of all three cards, and with this we managed to overclock it to a level that actually surpassed the GTX 980 at stock speeds. Your mileage may vary, of course, but this is undeniably a fantastic result. Add in the super quiet operation and semi-passive cooling mode, and you've got yourself a truly awesome graphics card."
Thanks for responses guys, I can see some ways I can drill my bays to accommodate the Gigabyte G1 in there.
So I think I will go with that one once I mod
Is there any other cards that overclock like a beast compared to Gigabyte G1?
Are the fans quiet on Gigabyte G1?
